Strange behavior from 4L60E
2000 GMC JIMMY
160,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
KDGAST
  • 6 POSTS
Replaced bad transmission with no reverse and the new to me transmission goes forward in reverse. Has a new neutral safety switch and back up lights come on but wheels turn forward.
Mar 18, 2016 at 10:02 PM
HMAC300
  • 48,601 POSTS
it may have the wrong clutch pak applied due to damage internally. If you got it from a junkyard get another one
Mar 19, 2016 at 4:34 PM
KDGAST
  • 6 POSTS
It didn't come from a junk yard but the truck it came from was in an accident and the owner was parting it out. I personally went to his house and witnessed the truck go in every gear including reverse.
Mar 20, 2016 at 9:39 PM
HMAC300
  • 48,601 POSTS
then check harness at transmission see if there is any damage there and scan for codes. does it do this while wheels in air or on the ground? Is the transmission full of fluid? What year did the transmission come from if it was from a pre 1995? If so then it is an OBD1 and will not work with your vehicle.
Mar 20, 2016 at 10:48 PM
KDGAST
  • 6 POSTS
With wheels in air. It is full of fluid and truck was a 1999 Chevy blazer
Mar 21, 2016 at 7:41 AM
HMAC300
  • 48,601 POSTS
What does it do when it is on the ground? The same? Tt may be just because the wheels are in air, but I kind of doubt it. But try it. If it does the same then it has either not enough pressure for reverse or a valve body problem and a transmission guy should look at it. Have you scanned for codes?
Mar 21, 2016 at 2:04 PM
KDGAST
  • 6 POSTS
No but I'm pretty sure it's junk I just test drove it and it doesn't want to shift at all it will but only after you floor it and then let up. Still no reverse I have the worst luck. Know anyone who wants a 2000 gmc jimmy with 2 bad transmissions? Lol cause that's all I can do is laugh.
Mar 26, 2016 at 6:05 PM
