Temperature gauge
137,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MONCHO6685
  • 118 POSTS
Hello again, when I turn off the engine the level on the gauge go to the high temperature, when I turn on the engine again it goes back to normal. What is happened here? Is it a serious problem?
Nov 2, 2018 at 11:04 AM
  • 55,561 POSTS
If you are not having any other problem this can be normal. Have you installed a new battery lately? Can you please shoot a quick video with your phone so we can see the gauge to be sure, that would be great. You can upload it here with your response.
Nov 4, 2018 at 3:26 AM
MONCHO6685
  • 118 POSTS
I will took the video this problem it is not all the time It is like it did it today and do it again in the next week, rarely but it do it. and by the way I want to change the coolant how I found the coolant fl22 that said in the manual and in the deposit? I am a beginner and I want to learn all that possible. Thanks.
Nov 4, 2018 at 4:32 AM
  • 55,561 POSTS
Yes put 50% coolant 50% water. Here is a guide that will help you:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Nov 5, 2018 at 12:41 AM
