Storing a vehicle for long periods of time in garage
1999 TOYOTA TACOMA
185,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
RUSSELCA
I park my truck in garage for long periods of time, i do not drive the truck on a daily basis, but will start it up two times a week to keep the battery from dying. i want to find out what would be better for the truck if i continue to only start it twice a week.
Dec 27, 2018 at 4:39 AM
  • 110,244 POSTS
First, the worst thing for any vehicle is lack of use. The best thing you could do is at least move it around so all seals, bearings, gears are lubricated. Things such as gaskets and seals have a tendency to deteriorate when they get dry from lack of use. As a result, when the vehicle is put back into service, leaks develop.
As far as the engine, make sure you change oil on a regular basis to avoid condensation to develop in the engine.
Honestly, when you start it to charge the battery, consider putting a couple miles on it a week.
Dec 27, 2018 at 7:17 AM
BMDOUBLE
  • 1,139 POSTS
Also keep the tank full of fuel to keep it from turning rotten.Today’s fuel has some ethanol in it that will absorb moisture and will not hold up to sitting dormant.
Dec 30, 2018 at 2:21 PM
