When it stalls, does it seem to be lurching forward or backwards or does it seem like a low idle related issue?
If it seems to be idling low, first check for engine vacuum leaks. Here is a link that shows how it is done:
Also, is the check engine light staying on when it is running? If so, you need to have the computer scanned. Most parts stores can do a basic test, but since the vehicle isn't driveable, see if you can find a parts store that will lend or rent one to you.
Here is a video showing how to scan the CAN bus system. CAN stands for computer area network This type of scan will check all modules in the vehicle.
https://youtu.be/InIlnsjOVFA
Aug 3, 2020 at 2:40 PM
