Overheated and stopped running
175,000 MILES • 2.4L • 4 CYL
L HARRISON
Overheated, won't start.
May 17, 2019 at 7:07 PM
Good morning,
Sounds like you may have either a failed head gasket or a failed timing belt.
I would start with a compression test.
Also, you need to have a leak down test done to see if compression is leaking into the cooling system.
May 17, 2019 at 9:48 PM
L HARRISON
Dear Roy, thank you for your advice. The mechanic did the compression test and one piston is frozen, so they've soaked it and will see today if all is not lost. Also they,discovered a hole in the radiator, the coolant reservoir was full. The question is, is it worth high expense to repair?
May 17, 2019 at 11:43 PM
You are welcome.
I would consider a used engine instead of repairing the engine.
You would be looking at $1,200.00 to $1,500.00 for a used engine installed but the repair could be two times that amount.
May 18, 2019 at 12:17 AM
L HARRISON
Hi Roy, so appreciative for your guidance. Am investigating with mechanic. Thanks for being there to help. This is my starving artist/musician son's car and your suggestion would alleviate worries of further catastrophic repairs. God bless you and your work.
May 18, 2019 at 12:24 AM
Always glad to help.
May 18, 2019 at 12:28 AM
