Stop running when I was driving
325,000 MILES
VIC1976
I was driving and stop running I put more gas in the tank nothing . I change the spark plug and the wire and the cap with the rotor and nothing . I turn the key 3 time and give me the code P1285 . What I need to do??
May 21, 2013 at 12:53 PM
SINBAD271
  • 169 POSTS
Does it turn over?
May 21, 2013 at 2:35 PM
VIC1976
When you turn the key the motor turn . Sometime give that kick to start but don't start
May 22, 2013 at 11:04 AM
SINBAD271
  • 169 POSTS
Check to see if your getting fire at the plug. Check and see if your getting fuel to injectors.
May 22, 2013 at 11:20 AM
VIC1976
Yes I get fire and get fuel I already test that I look all fuse and the fuel pump relay everything ok
May 22, 2013 at 11:33 AM
SINBAD271
  • 169 POSTS
Check your oil ,does it look milky, conduct a coolant pressure test, see if coolant is leaking on to the ground anywhere . Pull your plugs out see if any of the have a coolant smell to them, conduct a compression test on each cylinder. You may find an issue . It seems you may have a head gasket issue. Not for certain at this time. Tests must be done . Let me know the out come please thank you. I know it sound like a lot of work , but this is called pin pointing .
May 22, 2013 at 12:13 PM
