stop light fuse blows when pressing brake pedal
1997 CHEVROLET SUBURBAN
146,000 MILES
DAVID KUZNITZ
I'm a stumped. The brake fuse blows when stepping on the brake pedal.
Info:
1. The signal lights work fine, no blown fuse.
2. I can disconnect a connector at the fire wall which connects back to the rear lights. When I do this the fuse does not blow when I step on the brake.
3. I unplugged the rear light assemblies so I am sure it is not a problem here.
Need an inspiration
Aug 31, 2013 at 8:29 AM
SATURNTECH9
  • 30,869 POSTS
What color is the wire your disconnecting?
Aug 31, 2013 at 8:37 AM
CJ MEDEVAC
  • 11,004 POSTS
TRY REMOVING ALL OF THE BULBS IN THE REAR
SEE IF IT STILL HAPPENS
INSPECT THE SOCKETS
LOOK FOR MELTAGE ON THE SOCKETS AND THE WIRES TO THEM
INSPECT THE BOTTOMS OF THE BULBS
DISCONNECT THE WHOLE TAIL LIGHT HOUSING, IF YOU GET THIS FAR ALONG
GIMME THE EXACT NOMENCLATURE OF YOUR VEHICLE....ENGINE SIZE....ANY THING SPECIAL, LIKE DAYLIGHT RUNNING LIGHTS (DRL)
I CAN PROBABLY PULL YOU UP A "MITCHELL I" WIRING DIAGRAM FOR THAT SYSTEM (WANNA INSURE I GET YOU THE CORRECT ONE)........THIS MIGHT AID IN FURTHER DIAGNOSIS
YOUR TURN
THE MEDIC
Aug 31, 2013 at 8:48 AM
