I'm wondering if i can convert my 6 pin wire connection on my truck to a 4 pin connection to allow the 4 pin fuel pump to be used?
Jun 23, 2019 at 2:49 AM
✓Experienced Mechanic
Hi Jamaze,
Unfortunately, it is not the wiring that is the issue. It is the way the PCM controls the different pumps. You could wire it but the PCM needs to see different signals that the four wire pump just can't send so it won't operate properly.
Sorry I didn't have better news for you but it just isn't possible.
Jun 23, 2019 at 3:17 AM
JAMAZE
MEMBER
I pretty much thought that was the situation. thanks for the answer back..
