still have problem
100,000 MILES
ALFREDES
checked all things you said and replaced distributor, advanced timing, emptied beads out of plug in catalytic converter and swapped out fuel meter body. I am still having problems.
Jul 6, 2016 at 1:02 AM
HMAC300
  • 48,601 POSTS
so what is problem? scan for codes and check fuel pressure with a gauge should be 9-11 psi if tbi if carburetor much lower.
Jul 6, 2016 at 1:05 AM
  • 110,248 POSTS
Hi again. First, I think we need to make sure that the exhaust system isn't blocked (even though you worked on that). Next, we need to check engine compression.
Jul 14, 2016 at 11:44 AM
