Still have power to the fuel pump relay and cruise control with key off
350,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
JOHNPS
I have replaced the ECM, fuel pump relay, ignition switch, starter relay, alternator and key switch but it still drains the battery. what is the problem?
Jan 29, 2019 at 11:55 AM
SCGRANTURISMO
  • 4,897 POSTS
Hi Johnps, my name is Alex and I will be helping you.
You are having a parasitic draw issue. Here is a link along with a video at the end that will help you track your problem down. Let us know what you find out. Thanks. https://www.2carpros.com/articles/car-battery-dead-overnight
Jan 30, 2019 at 4:50 AM
JOHNPS
The problem I have does not involve accessories, the problem is that the power stays on to the fuel pump and the cruise control with the ignition off. I have replaced almost everything but haven't found the problem. any suggestions?
Feb 3, 2019 at 6:19 AM
SCGRANTURISMO
  • 4,897 POSTS
Okay, it sounds to me like you have a short to power in the A/C circuit somewhere. The A/C and fuel pump do use the same circuit. I am sending you wiring diagrams for both. Let us know what you find out. Thanks.
Feb 3, 2019 at 9:42 AM
