Still has a “lifter ticking” like noise after replacing the lifters?
190,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
STRYKER627
Changed the lifters in my truck listed above 1500 and now the ticking noise is still there. It’s definitely not as loud but it’s still there. Any ideas on what this is? Please help!!
Sep 30, 2024 at 9:28 PM
  • 55,676 POSTS
Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response. We need to hear the noise, so we know which direction to go to help you fix the car. It takes time to upload so please be patient.
Did you check for a broken valve spring or a bad roller rocker? Also, it could be carbon on top of the piston, or you have a seized wrist pin, can you tell which side of the engine noise is coming from?
This guide may help:
https://www.2carpros.com/articles/engine-noises
Please check the images below for more trouble tree information. Check out the images (below). Please let us know what happens.
Oct 1, 2024 at 7:51 AM
