Still getting noises from fron wheels when braking.
72,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
NEUGEN
Hey, I asked for some advice about my brakes from you guys and it was indeed the rotors. They were extremely warped. I had them replaced along with the pads. Everything seemed ok for about 40 miles then the noise started coming back very slightly. It's more of a clunky sound rather than the grinding from before, it's only when I brake now though. The same thing is happening, when I have driven at higher speeds down the motorway it makes it worse. I did notice when the new rotors were fitted I rotated the wheel and you could hear a faint metallic scraping /scuffing sound.This was before the car was lowered off the ramp. Just want to find the problem. Have they put on the wrong discs or is there a deeper problem putting stress on the brakes? Cheers for the help in advance
Mar 2, 2014 at 6:54 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
it sounds like they might have left something loose in there and id get it back to them straight away. even if theres nothing loose it shouldn't be making these sounds when youve paid good money for new brakes.
Mar 2, 2014 at 8:00 AM
