Stiff steering and warning lights?
2015 HYUNDAI VELOSTER
70,000 MILES • 1.6L • 4 CYL • AUTOMATIC
AMY BREWER
The ESP, ABS and traction control lights all came on my vehicle listed above and now my steering wheel is extremely stiff.
Nov 10, 2024 at 11:08 AM
  • 110,241 POSTS
Hi Amy, this can be the result of a few things. For example, a faulty wheel speed sensor can cause the traction control, ESP, and ABS to all come on at the same time. The steering is a different issue.
Before you lost power assist to the steering, were there any odd sounds from the engine compartment such as a humming sound or anything out of the ordinary?
Let me know that. Also, what really should be done in this situation is to have the can-bus scanned to identify fault codes that may point us in the right direction.
CAN stands for controller area network. The different modules are tied together via a few wires. This type of scan will communicate with all modules regardless of which one has recognized a problem.
Here is a link that shows how it's done:
If that isn't something you can do or have done, stop at a local parts store such as AutoZone and have them scan the computer. Although their scan tools cannot do as much as a shop's, it may pull something to help me make a determination.
Let me know your thoughts and questions.
Nov 11, 2024 at 9:31 AM
