Stereo wiring diagram
66,200 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
TRISTAN JOSEPH RAMIREZ
I want to add a line out converter for an Amp and I need a wiring diagram for the car listed above with navigation without Harman Kardom.
Apr 12, 2021 at 10:47 PM
  • 110,248 POSTS
I have two options with nav. Neither indicates Harman Kardom. However, I know that is an upgrade and I believe it has a seperate amp.
If you look at pic 1 below, I listed the options I have and highlighted the one I picked. If that is incorrect, let me know.
I had to cut the pics in half to make them readable. However, I did overlap them so you can follow from one to the next.
I hope this helps. Let me know if that was the wrong system
Apr 13, 2021 at 12:55 PM
