After replacing the stereo vehicle shuts off while driving
189,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
TIARARICH46917
I switched my stereo to my Denali and it locked stereo up switched it back to my suburban turned on no problem. now my suburban will just shut off no reason driving down the road and sometimes it won’t start at all.
Mar 31, 2021 at 3:23 PM
  • 55,628 POSTS
This sounds like the crankshaft angle sensor or the fuel pump has gone out. when you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds? These guides should help us fix it.
https://youtu.be/dCjmRL3p4Cs
and
Also, lets run the codes to see what come up.
Apr 3, 2021 at 4:06 AM
TIARARICH46917
Yes, you can hear fuel pump kick on that was replaced not to long ago. not throwing any codes. it did start up run for 45 minutes then shut off. haven't checked crankshaft sensor. did reprogram key fob. so will let you know.
Apr 3, 2021 at 7:25 PM
  • 55,628 POSTS
Apr 4, 2021 at 2:39 AM
