I recently installed new front lower ball joints on both sides. After doing so went to drive it and now I have wobble in the steering which was not present before the new ball joints. I have checked the outer tie rod ends and they are solid, no slop in them. Had the front end aligned as well and still have this wobble. Also after installing the ball joints my VSA, VTM-4 lock triangle! and ABS lights are staying on. Advance Auto checked the computer with the scanner they have and one of the codes showed short in right front ABS sensor. Would that cause all the other lights to stay on? Any help with this would be appreciated.
Jun 13, 2018 at 8:56 PM
