Steering wheel shaking over bumps
2004 VAUXHALL VECTRA
109,000 MILES • 1.8L • MANUAL
ANDYVECTRASRI
Hi, I have vehicle listed above Sri. When ever I go over and bumpy roads the steering wheel shakes very badly from side to side. I have noticed that the whole exhaust also swing side to side over any bumps. Does anyone know if this can cause to steering wheel to shake side to side? One mechanic has said that this would not cause it. Also the car has a boar exhaust .
Aug 2, 2018 at 9:25 PM
  • 55,224 POSTS
It sounds like you have tie rod ends that are worn out. Here is a guide that will help you see if this is the problem and what you will need to do to fix it:
https://www.2carpros.com/articles/tie-rod-end-replacement
Cheers, Ken
Aug 5, 2018 at 11:23 AM
