Steering wheel shakes
90,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
DIANA REGAN
Replaced, three motor mounts, thermostat, air filter, fuel injector, new battery and alternator, and tightened vacuum hoses. Check engine light stopped coming on when I replaced purging valves. Steering wheel still shakes.
Dec 26, 2016 at 11:18 PM
CJ MEDEVAC
  • 11,000 POSTS
This is a possibility
Swap your front tires (one at a time) to the rear. Driving between the swapping. This might let you know which tire is the problem.
I've answered others with similar issues. Here's a link to one.
https://www.2carpros.com/questions/1992-chrysler-new-yorker-does-front-drivers-side-tire-make-thumping-noise-drive
Return with good new!
The Medic
Dec 27, 2016 at 10:03 AM
