My car gets a bad shake in steering wheel when I accelerate doing over 70 kmh. When I turn to the right there's like a grinding noise coming from front left of car and when I hit bumps or even sometimes just the contour of the road at speeds upwards from about 40 kmh there's a loud knock that comes from the front of car somewhere (I just can't seem to pinpoint exactly where it's coming from).
I have so far replaced:
L+R Front Lower Control Arms
L+R Front Driveshafts
L+R Front Wheel Bearings
L+R Front Lower Ball Joints
L+R Front Sway Bar Links
L+R Front Brake Pads
I'v replaced all these and the wheel still shakes like crazy & knocks when going over bumps.
Should I have replaced wheel hub as well when I fitted the new wheel bearings?
Also there seems to be a lot of movement in my motor but i'v checked engine mounts and they seem fine?
It has gotten worse since I had my clutch replaced but the mechanic who done clutch told me that it's got nothing to do with the clutch he installed (he had to remove K frame, driveshafts etc., and drop engine as the clutch is on the side of engine and can't be accessed any other way
I have it booked in to get 2x new Front Tires + a Wheel Alignment + replacement of both Steering Outer Tie Rod Ends.
Has anybody else had these problems with their vehicle listed above AWD 2.4L (RD7)?
Any idea what else it could be because I'm running out of ideas? (eg. adjustments or anything)
Jan 10, 2020 at 9:56 AM
