Steering wheel shaft loose?
245,555 MILES • 5.3L • V8 • 4WD • AUTOMATIC
HD1200
  • 61 POSTS
I’m trying to figure out why the shaft connected to the steering wheel is very loose. I tried to tighten the 2 small torx bolts but they stripped. I checked the shaft below that and it seems fine.
May 21, 2024 at 12:12 PM
STEVE W.
  • 15,416 POSTS
Do you mean the intermediate shaft the has a bolt on top and one at the bottom? Or the upper shaft in the tilt column? Where are they loose? Don't recall any torx bolts that are not inside the column.
May 22, 2024 at 11:46 AM
HD1200
  • 61 POSTS
Upper shaft with tilt.
May 22, 2024 at 12:14 PM
HD1200
  • 61 POSTS
I think I figured it out, I checked the cap that covers the bearings that shaft sticks through was bent I’m going to get one from junkyard see how that’s does.
May 22, 2024 at 12:17 PM
STEVE W.
  • 15,416 POSTS
Bent isn't good, that usually happens if the tilt gets loose and people use the wheel as a handle to get in.
May 22, 2024 at 12:29 PM
HD1200
  • 61 POSTS
Right I’ll update once I get time to get part.
May 22, 2024 at 10:06 PM
HD1200
  • 61 POSTS
Thanks for input.
STEVE W.
  • 15,416 POSTS
No rush, life goes on and getting parts these days is becoming a difficult thing. In this case I'd probably grab a complete column and go through it and just swap the column in.
May 23, 2024 at 3:45 AM
HD1200
  • 61 POSTS
Yes, I was thinking that trying to get it done trying this first If it doesn’t work that’s my plan B.
May 23, 2024 at 4:19 AM
HD1200
  • 61 POSTS
Hey, if you don’t mind can you send me procedure for removing steering column just in case I have to go?
Thanks
May 23, 2024 at 4:55 AM
STEVE W.
  • 15,416 POSTS
Turn the steering so that the front is straight. Now go under the column and you will see a hole in the plastic, there is an alignment pin they sell but I use a piece of steel rod and run tape around the column to hold it. That prevents damage to the Clock Spring and keeps the wheel centered. Now remove the panel under the dash to get to the column. Remove the body module and set it aside, disconnect the shift cable from the shift rail. Then unplug the harness from the column. Now remove the deflector cover that is over the column. Then the pinch bolt at the top of the steering shaft (I'd also remove the lower bolt after checking if the shaft rattles, if it doesn't you might want the lower shaft as well) Now remove the two nuts from the flange and the two that hold it to the slide blocks and you have the column out. Reverse the process to install it, but tighten the 4 nuts to 22 ft lbs, they are part of how the column collapses. Sometimes you need to use a scan tool to reset the steering sensor, other times you don't.
May 23, 2024 at 5:27 AM
HD1200
  • 61 POSTS
Thanks
May 23, 2024 at 5:57 AM
STEVE W.
  • 15,416 POSTS
No problem. Keep us informed please, it may help others.
May 23, 2024 at 6:01 AM
HD1200
  • 61 POSTS
Will do.
May 23, 2024 at 6:39 AM
