Where can I find the steering wheel fluid reservoir and how much should I put? What brand is the best?
Oct 25, 2019 at 6:51 AM
✓Experienced Mechanic
Good afternoon,
The fill is on top of the pump. The pump is at the bottom of the engine back by the firewall. It is a pain to get back there to the fill cap. You will need a long thin funnel to add the fluid.
Images (Click to enlarge)
Oct 25, 2019 at 7:33 AM
PCULQUI
MEMBER
What do you think about this product? It claims to stop leaks.
Image (Click to enlarge)
Oct 26, 2019 at 8:19 AM
PCULQUI
MEMBER
When power steering fluid pump reservoir is low, can you just re-fill it or do you have to bleed out the old and put the new in?
Oct 26, 2019 at 8:43 AM
PCULQUI
MEMBER
Is the power steering switch a solution to leakage?
Oct 26, 2019 at 8:44 AM
Okay, no sealer, ever. That stuff is junk and never works.
It will not stop the leak and will destroy the seals and you will end up replacing the pump and steering rack.
Yes, you can just add fluid to it.
As far as the switch, only if it is the source of the leak.
