How to remove and repair the Steering Wheel Column?
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
BRIE ALDRIDGE LAMKEY
My steering wheel decided to fall when I was driving. It won't stay in place like it's loose or broken. I'm trying to take my column off, but I can't get the borrow part off due to my ignition pegs. I can't take my ignition cover off. That being said I can't get the broom of my column off. How do I get this fixed?
Nov 29, 2021 at 1:12 AM
  • 110,246 POSTS
When you say it fell, do you mean the entire column or just the tilt? I attached the directions for removal of the trim cover removal. Take a look at the directions and let me know if that is what you needed.
Also, I added the last pic so you can see where and how the column is mounted.
Let me know if this helps, and any specifics that may help me further help.
Nov 29, 2021 at 10:00 AM
