Steering wheel clicking noise
60,000 MILES • 4WD • AUTOMATIC
ZIKA PERIC
My car makes a clicking noise when I turn the wheel.
Dec 20, 2019 at 4:02 AM
This is called the airbag spiral spring or clockspring. I attached a bit of info on this but if you are going to do this yourself, make sure you disconnect the battery because you will be removing an airbag.
https://www.2carpros.com/articles/symptoms-of-a-bad-airbag-clock-spring
https://www.2carpros.com/articles/steering-wheel-clock-spring-removal
Dec 20, 2019 at 11:44 AM
