steering wheel bump feeling
98,000 MILES • 4 CYL • 2WD • AUTOMATIC
MIANHI
While turning I feel a "bump" in the rotation of the steering.
Oct 31, 2020 at 12:50 AM
  • 110,248 POSTS
When this happens, does it make any noise? I came across a technical service bulletin (TSB) related to a rattle when hitting bumps or turning the wheel.
Take a look through this. This describes the issue and how it's repaired. The attached pics correlate with the TSB.
_____________________________
2010 Hyundai Elantra L4-2.0L
Steering - Steering Column Rattle
Vehicle Steering and Suspension Steering Canada - Steering - Steering Column Rattle
NO. 11-50-004
DATE DECEMBER 5, 2011
MODEL ELANTRA (HD), ELANTRA TOURING (FD)
SUBJECT
ELANTRA STEERING COLUMN RATTLE
Some 2007-2010MY Elantra and 2009-2010MY Elantra Touring vehicles may exhibit a slight rattle noise from the steering column while driving on rough roads at low speeds or while turning the steering wheel.This condition is cause by the worm shaft flexible coupling in the motor driven power steering (MDPS) column. This bulletin provides the procedure to repair this condition.
AFFECTED VEHICLES
Some 2007-2010MY Elantra and 2009-2010MY Elantra Touring vehicles manufactured between July 1, 2007 and April 24, 2009.
pic 1
PARTS INFORMATION
pic 2
pic 3
KIT COMPONENTS
Pics 4 to 11
SERVICE PROCEDURE:
WARRANTY INFORMATION
OFP: 56310-2H301 (Qty. 0) Description:Elantra Steering Flexible Coupling Replacement Consequential:56380-2H000FFF (Qty. 1) OP Code: 56380F00 T1: N29 (Abnormal Noise) T2: C24 (Improper Clearance) LTS: 1.3 M/H
OFP: 56310-2L300 Qty. 0) Description:Elantra Touring Steering Flexible Coupling Replacement Consequential:56380-2L000FFF (Qty. 1) OP Code: 56380F00 T1: N29 (Abnormal Noise) T2: C24 (Improper Clearance) LTS: 1.3 M/H
NOTE:
Normal warranty policies and procedures apply.
Let me know if this helps. Also, if you have other questions let me know.
Oct 31, 2020 at 12:17 PM
