steering wheel and horn does not work after installing new evap temp sensor in dashboard.
140,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
SAMIJAY313
Hello, I have a 2006 Lincoln Zephyr and the ac was not working. I had to remove the dashboard to install a new evap temp sensor and now the ac is working. After the install I start the car to find out that all my steering wheel controls don't work. cruise control, radio controls, volume up and down etc and also the horn does not work. steering wheel controls and horn were working before I installed the evap temp sensor inside the dashboard. I checked all fuses and all are good. What could be the problem?
Nov 13, 2014 at 4:55 AM
  • 110,251 POSTS
Have you checked to make sure nothing is disconnected? Have you checked for a body ground that you may have unplugged
Nov 13, 2014 at 8:16 AM
