Steering wheel
33,000 MILES
PHIL PATTEN
I would like to mount an auto steering wheel on my kubota tractor. How do l find the correct hub?
Jan 25, 2019 at 12:57 PM
STEVE W.
  • 15,418 POSTS
For that you would probably need a custom adapter made. If you plan to use one of the aftermarket wheels it would be easier as most of those usually have a simple hub. There are heated steering wheels made for the Kubota utility vehicles that might work.
The first step would be to find out what the steering wheel you currently have uses as it's mounting interface. If it's splines, keyed or some other shape.
Jan 25, 2019 at 1:20 PM
PHIL PATTEN
Thanks. Bye
Jan 25, 2019 at 1:38 PM
