After replacing the ignition switch actuator turn signals do turn back, wiper fluid does not spray and horn honks when turning
800,000 MILES • 2.8L • V6 • 2WD • AUTOMATIC
DAECERBERUS
i changed the ignition switch actuator on the car and now the turn signal won't spring back, the windshield washer fluid wont spray, and the horn honks every time i turn, what did i do wrong?
Jul 15, 2021 at 3:37 PM
It is hard to say what you would have done wrong to cause all this to happen but clearly there is a connector not seated or possibly the harness is rubbed through and touching a piece of metal which is grounding it out.
No matter what we are going to have to remove it and inspect what happened.
I included the diagrams and process on the ignition for you to review.
Please run through this and let us know if you have other questions and what you find. Thanks
Jul 16, 2021 at 12:01 PM
