I need to remove steering pinion and rack from housing
125,000 MILES • 5.7L • V8 • 2WD • MANUAL
DBMAJ040352
Before I apply real force I'd like direction from someone that has done this work.
Jan 18, 2021 at 6:23 AM
  • 55,758 POSTS
You must remove the bottom cap from the lower part of the rack pinion (#14). This exploded diagrams should help us. Check out the diagrams (below). Let us know what happens and please upload pictures or videos of the problem.
Jan 19, 2021 at 10:13 AM
DBMAJ040352
Ken, thanks for the diagram, but I needed to remove the rack and pinion from the housing to replace all seals gaskets etc. I have had several C5's and mixed results purchasing re-manufactured racks so this time I bought a rebuild kit and will restore myself. I am about 90% disassembled at this point and will send off some photos and text description after everything is cleaned which hopefully will be of help to you and others in the future.
Jan 21, 2021 at 5:29 AM
  • 55,758 POSTS
That would be great, please send pic or upload a video to help others, that's what we are all about.
Jan 22, 2021 at 2:29 AM
