Steering rack
2008 AUDI A4
108,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
EAMONNWALL
Hi, i just ordered a steering rack from UK with a speed sensor as i think it has one but not sure. it is hydraulic powered. my question is, after paying for this if my car previously has no speed sensor rack then can i still use this rack i ordered? please. Many thanks,
Eamonn
Nov 3, 2017 at 7:05 PM
  • 31,937 POSTS
The sensor will be a pressure sensor, it tells the PCM that steering load is applied and at low speed and low rpm it increases engine rpm slightly to compensate for the added engine load. All hydraulic power steering systems have this, i need some more information as to where your switch is located. most are in the rack, but they can also be in the high pressure line. i need to know body version Quattro? Base? etc and i only see a two liter version not a 1.8 as noted in your post. please re check and also a VIN number can help as well.
Nov 4, 2017 at 8:15 AM
EAMONNWALL
Hi, and thank you for replying. 046284 is the VIN number. it is 1.8 TFSI two wheel drive and sensor is located on the rack. new one on way will have speed/angle sensor fitted to it. question is really is this compatible with my car if present rack has so speed/angle sensor ? Thank you in advance.
Nov 4, 2017 at 8:50 AM
  • 31,937 POSTS
Okay, with that information i cannot see any sensor on your rack, just the steering angle sensor behind the steering wheel. if the rack supplied has a sensor, i do not think that it will be a problem, as it just monitors steering oil pressure.
Nov 4, 2017 at 9:53 AM
EAMONNWALL
Cool. thank you so much for your advice. i will let you know.
Nov 4, 2017 at 7:08 PM
  • 31,937 POSTS
Okay, hopefully it is all good.
Nov 4, 2017 at 8:07 PM
