Steering problems
84,000 MILES • 1.8L • 4 CYL • FWD • AUTOMATIC
SEAN92
  • 18 POSTS
A few weeks ago it was raining really hard in my town and I noticed my speedometer was acting weird. It was lagging. I would be stopped and the mph were still not at zero. Now a few weeks later my steering would get stiff and than return to normal. Intermittently I would lose partial power steering. Now my power steering is stiff but not totally gone. (Around this time I heard a loud metallic noise from my rear passenger side wheel well when driving, it was inspected and nothing looked out of place).The steering is only loose(normal) when I start the car and lasts a couple seconds. I am hearing nothing from the pump, my power steering fluid is new(the problem existed before the new fluid as well as after). I also got an alignment and the results showed it was pretty much all good (rear right was -3.00. Cannot change it because of manufacturer). Also, when I make a turn the steering wheel wobbles slowly back to center position.
Feb 25, 2017 at 12:45 PM
KHLOW2008
  • 41,812 POSTS
The speedometer acting weirdly could be due to a failing vehicle speed sensor. Check the harness connector for proper connection and cleanliness. Contamination's due to presence of water can result in poor connectivity.
For the power steering, check the belt tension. If the fluid had been very dirty prior to replacing, remove the reservoir and check the filter internally for clogging. Clean it up if necessary.
Steering returning with slow response could be due to faults with the steering rack, ball joints or universal joints (which are rare).
Feb 27, 2017 at 4:15 AM
SEAN92
  • 18 POSTS
I replaced the whole power steering reservoir because the screen in the old one was clogged, the problem still persisted. Can the power steering be effected if the belt tension-er is causing the belt to be loose but no sound is being created from the loose belt?
Feb 27, 2017 at 5:33 AM
KHLOW2008
  • 41,812 POSTS
Yes, but this does not seem to be the case. Most likely the pump is weak or leaking pressure internally.
Feb 27, 2017 at 9:29 AM
SEAN92
  • 18 POSTS
I took this picture of the line that leads into the steering rack from the pump
Feb 27, 2017 at 11:04 AM
KHLOW2008
  • 41,812 POSTS
This is the return hose and don't seem to be leaking badly. Only some fluid seepage. tightening the clamp might stop the leakage.
Feb 28, 2017 at 12:06 AM
SEAN92
  • 18 POSTS
The pump has remained silent this whole time. Is it possible that it can be quiet and still have a problem?
Feb 28, 2017 at 12:53 AM
  • 55,721 POSTS
Yes the pump is probably the cause of the problem 9 times out of 10 this is the case.
Best, Ken
Mar 2, 2017 at 2:50 AM
