There is a rubbing sound when turning the steering wheel?
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
I assume you have seen this before. When you turn the steering wheel whether parked or while moving there is a rubbing sound which sounds like around the coils. I have seen it in other US made vehicles.
Feb 8, 2024 at 2:05 AM
  • 55,746 POSTS
Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response. We need to hear the noise, so we know which direction to go to help you fix the car. It takes time to upload so please be patient.
Feb 8, 2024 at 8:13 AM
BHAMDOC1973
  • 2,007 POSTS
Will be hard to hear, more felt than heard. I wish i could remember what SUV i had that did the same, i think a Ford Edge, sounds like the wheel is turning but the spring is hung on and not moving with the strut. Heard it many cars before just never knew what the issue is.
Feb 8, 2024 at 8:37 AM
  • 55,746 POSTS
There is a TSB on that problem which requires the removal of the steering column, cutting away a portion of rubber, lubricating it, and reinstalling it.
Feb 9, 2024 at 1:14 AM
BHAMDOC1973
  • 2,007 POSTS
Can you please send it?
Feb 9, 2024 at 1:48 AM
BHAMDOC1973
  • 2,007 POSTS
Ugh, turned out just a bit low on power steering fluid which is under the right-side fender liner.
Feb 13, 2024 at 8:30 AM
  • 55,746 POSTS
Thanks for letting us know.
Feb 14, 2024 at 3:08 AM
