Steering lock
6,700 MILES • 4 CYL • AUTOMATIC
INMYHEART28
  • 223 POSTS
If my steering is locked because the car is off and I (by mistake) turn the locked wheel with my leg, would that hurt the steering?
Jan 19, 2016 at 9:42 AM
CJ MEDEVAC
  • 11,000 POSTS
EXPLAIN EXACTLY WHAT YOU DID WITH YOUR LEG?
THE MEDIC
Jan 19, 2016 at 10:22 AM
INMYHEART28
  • 223 POSTS
I moved it along a locked streering wheel when the car was off and thus the wheel was locked (but slightly moveable.) Does that make sense?
Jan 19, 2016 at 10:24 AM
INMYHEART28
  • 223 POSTS
Thus the steering wheel moved while locked but slightly moveable.
Jan 19, 2016 at 10:27 AM
CJ MEDEVAC
  • 11,000 POSTS
YES
TO SIMPLIFY MY EXPLANATION, I'LL EXPLAIN THIS IN A TYPICAL WAY
IN YOUR STEERING COLUMN THERE IS LIKE A COLLAR OR DISC WITH SLOTS CUT IN IT. WHEN IT IS ACTUALLY COMPLETELY LOCKED A PIN IS DROPPED INTO ONE OF THE SLOTS
IF YOU HAPPEN TO LOCK IT BETWEEN THE SLOTS, IT'S REALLY LOCKED, BECAUSE IF YOU MOVE THE STEERING WHEEL EITHER WAY, THE PIN WILL DROP INTO A SLOT. THEN THE "LITTLE BIT" OF FREE MOVEMENT CEASES.
I THOUGHT YOU WERE GONNA TELL ME YOU KICKED IT WITH SUPER-HUMAN FORCE TO ATTEMPT TO UNLOCK IT! LOL!
DOES THIS SOUND LIKE YOUR SITUATION?
THE MEDIC
Jan 19, 2016 at 10:33 AM
INMYHEART28
  • 223 POSTS
It was just a simple movement to the point of where it was locked. I just rubbed up against it. Little strength and it stopped at the locked position. I didn't use super human strength. Do you think I should be okay?
Jan 19, 2016 at 10:38 AM
INMYHEART28
  • 223 POSTS
Again, do you understand what I am saying and will I be okay?
Jan 19, 2016 at 10:52 AM
CJ MEDEVAC
  • 11,000 POSTS
NOPE!
SOUNDS LIKE YOU NEED A JEEP CJ OR A WILLYS
ANYTHING ELSE IS JUST TROUBLE WAITING TO HAPPEN!
SEE MY PICS BELOW
(YOU MAY GET A FEW MORE YEARS OUT OF YOURS!) (MINE ARE 40 AND 70 YEARS OLD)
THE MEDIC
Jan 19, 2016 at 10:56 AM
INMYHEART28
  • 223 POSTS
Your cars look great but I asked a serious question. Will rubbing your leg lightly against a locked steering wheel cause any trouble?
Jan 19, 2016 at 10:59 AM
CJ MEDEVAC
  • 11,000 POSTS
NEGATIVE,
A STEERING LOCK IS YOUNGIN' PROOF!
YOU NO HURTY IT!
THE MEDIC
Jan 19, 2016 at 11:02 AM
