Steering Issue
160,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
GREGORY MICHAEL YATES
  • 89 POSTS
Hi folks,
About 6 months ago, I replaced my rack and pinion steering and power steering pump and outer tie rod bushings (moog kit).
Now last night when I go to make a right turn it is very difficult and then halfway through the turn it suddenly
becomes easy.
I never replace the outer tie rod like I should have 6 months ago.
I will update this with some pictures tomorrow morning.
But in the meantime what do you thinking about it may be being the outer tie rods? Or?
Thanks in advance if you can help me I appreciate it!.
Feb 11, 2021 at 3:34 PM
Good morning,
Did you do the tests I suggested with your previous posts?
It sounds like the rack itself is causing this issue.
https://www.2carpros.com/articles/power-steering-problems
I attached YouTube videos for you to view.
https://www.youtube.com/watch?v=_CE80mGMGFU
https://www.youtube.com/watch?v=IoL8DTsq4Ek
Feb 17, 2021 at 5:29 PM
