There is a grinding noise and sticking in the steering when turning?
80,000 MILES • 6 CYL • AUTOMATIC
JLHARRISEYE
steering wheel making grinding noise and sticking.
Jan 30, 2021 at 4:27 AM
Can you get a recording of this because I think this would be an issue with the clockspring but normally they make a clicking noise when turning. Here is a guide that will help with this:
https://www.2carpros.com/articles/clicking-sound
However, if there is a grinding noise and the steering is sticking then the other likely cause is the pump. Here is a guide that will help with the replacement if this is what it turns out to be but these two issues are very different so a recording will help figure this out. Thanks
https://www.2carpros.com/articles/how-to-replace-a-power-steering-pump
Jan 31, 2021 at 7:01 AM
