Steering Icon Illuminated
2009 VOLKSWAGEN JETTA
240,366 MILES • 2.5L • 5 CYL • 2WD • MANUAL
ROND225
  • 11 POSTS
I disconnected the battery and when I reconnected the battery a steering wheel icon showed
up. I did some research and found out the electronic steering needs to be reset but the procedures I found didn't work.
Apr 14, 2022 at 7:42 AM
This is true that the module most likely needs to be reset but that may require a scan tool to do what is called an initialization.
However, before we do anything we should check to see what codes are there.
Here is a guide that will help with checking the codes:
When you drive the vehicle does the power steering operate? Have you noticed anything different other than the light?
Basically, we should have a code that will point us in the right direction so let's start with this and go from there.
Thanks
Apr 15, 2022 at 6:06 AM
