Steering hard
100,000 MILES • 1.2L • 4 CYL • MANUAL
PRASHANT KANT
My steering acts normal at standing position but as vehicle moves it gets hard as speed increase. at above 60 kmph steering gets so hard that I have to use real power to manage it.
As speed decrease it acts normal again.
Apr 16, 2017 at 1:07 AM
HMAC300
  • 48,601 POSTS
this may be a rack and pinion failing, but a local mechanic should check this out. check to see if fluid is full in reservoir, but it can also be a bad pump/belt and tension-er.
Apr 16, 2017 at 1:26 AM
PRASHANT KANT
It is steering is not hydraulic functional. There is motor for it.
Apr 16, 2017 at 1:29 AM
HMAC300
  • 48,601 POSTS
our manual shows hydraulic, but we are in US. if yours is electric then it still should be seen by a mechanic where he can scan for codes. check all fuses as well.
Apr 16, 2017 at 4:54 AM
