Steering gearbox
65,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
DEETRUCK7
I replaced my gearbox because it was leaking. After install I turned the wheel back and forth to bleed the air out, it was working fine . After i drove it ,the steering was hard to turn. should I empty it and bleed it or what do you think I should do?
Mar 11, 2018 at 12:33 AM
Good afternoon.
I would start by flushing the system with about one gallon of fluid. then bleed it again and see if it works.
If it remains the same it may be the pump that is the issue.
Mar 11, 2018 at 1:27 AM
