Steering column installation issue?
100,000 MILES • AUTOMATIC
CARGUY7
I had to replace my steering column, but now I can’t get the new steering column to go into the steering shaft so I can tighten the pincher bolt. Any suggestions would help please.
Nov 9, 2022 at 9:12 PM
  • 110,246 POSTS
Are you referring to the intermediate shaft? I attached a pic below of what I'm referring to. Let me know if that is correct.
If it is, is the issue the shaft seems too big for the joint, or is it an alignment issue?
See pic below.
Nov 10, 2022 at 12:09 PM
