Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
2500
Steering
Column
Replace/Remove
Steering column
1990 CHEVROLET 2500
283,000 MILES • 5.0L • V8 • 2WD • MANUAL
STEVE HENNI
MEMBER
Will a automatic column work in manual floor mounted shift and will neutral safety switch engage once I remove the autos shift rod?
Jul 4, 2017 at 8:31 AM
Experienced Mechanic
Yes the column with work in the truck, you will not need to worry about the neutral safety switch becasue it is mounted to the clutch pedal.
Cheers, Ken
Jul 5, 2017 at 10:25 AM
STEVE HENNI
MEMBER
Thank you very much since they are so expensive this helps a lot
Jul 5, 2017 at 10:36 AM
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Jul 5, 2017 at 10:48 AM
Add image or video
Ask a new question
Engine stalls while driving
Engine won't crank
