Steering column swap
178,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
JTTRAV
I want to change out my steering column and want to know what vehicle's steering column will fit my 1990. It doesn't have tilt and I would like to put tilt in if possible.
May 20, 2022 at 7:20 PM
JTTRAV
I am going to the salvage yard this morning and I know that they don't have any 1990 Cavaliers or any cavaliers, so knowing what will interchange would be a great help. Thank you
May 20, 2022 at 7:26 PM
JTTRAV
Well, I'm about to find out on my own thanks anyway.
May 20, 2022 at 11:07 PM
SQM
  • 6,383 POSTS
For the Cavaliers they use the same column (non-tilt) from 1990 to 1994 also the Pontiac Sunfire 1990 to 1994 uses the same steering column.
This is the OEM part number for the non-tilt column: 26003384.
I have attached the replacement procedure below.
Let me know of any questions.
https://www.2carpros.com/articles/steering-wheel-removal
May 21, 2022 at 1:29 AM
