Steering issue when hitting a bump
140,000 MILES • 5.8L • V8 • 4WD • AUTOMATIC
BISHO.LARRY
I have had the entire front end rebuild two rebuild gearboxes. It turns perfect no loose play. Does not seem to hold the road . It will do find hit a bump and you have to correct.
Jul 11, 2018 at 4:27 AM
  • 110,248 POSTS
Can you tell me what components were replaced? Were the tracking bar bushings replaced? Control arm bushings?
Let me know everything that was done.
Thanks,
Jul 12, 2018 at 1:39 PM
BISHO.LARRY
New tires, new shocks, two rebuilt gearboxes, steering box, tie rods, ball joints, sleeves, new cambers, an alignment.
Jul 15, 2018 at 12:13 PM
  • 110,248 POSTS
Welcome back. I strongly recommend checking the radius arm bushings. The radius arm is attached between the front axle and the frame of the vehicle. If there is excessive wear or play in the bushing, the axle can move.
I found a picture of one online for you to see where the new mount and bushing is located. If everything is new on the front, this would be a good suspect.
Let me know what you find.
Jul 15, 2018 at 1:15 PM
BISHO.LARRY
Thanks for your help that helped a lot. Still have some but it is acceptable now. Thanks for your help.
Oct 9, 2018 at 1:49 AM
  • 110,248 POSTS
That is good news. Let us know if you have questions in the future.
Oct 9, 2018 at 10:24 AM
