The steering pulls hard to the right?
187,000 MILES • V6 • 2WD • AUTOMATIC
CHRISDFEDRIC
And it is all around squirrelly.
Apr 22, 2023 at 2:20 AM
  • 110,248 POSTS
Does it pull at all times or when the brakes are applied? Have you checked the steering components such as tie-rod ends and ball joints? Are there any odd sounds you have noticed? Is there anything that causes it to stop pulling?
Not always, but often a hard pull is caused by a stuck or inoperative brake caliper that either holds pressure at all times or does nothing when the brakes are applied.
Let me know as much as you can.
joe
Apr 22, 2023 at 1:44 PM
CHRISDFEDRIC
I haven’t done much testing of it. Pulls while accelerating. And when I say pulls, I mean it will pull the wheel out of your hands.
Apr 24, 2023 at 4:19 AM
  • 110,248 POSTS
Have you checked at the rear axle for a problem with the trailing arms? I've seen them rust a break.
Take a look at the attached pic and let me know.
See pic below.
Apr 24, 2023 at 11:34 AM
