When you speed up a bit- wheel jersey to one side- when you slow down- wheel jersey to other side- not really bad but is noticeable definitely.
Apr 27, 2023 at 3:53 PM
✓Experienced Mechanic
It sounds like there may be an issue with the control arm bushings. Have you checked the suspension and steering components?
If not, lift one front wheel off the ground at a time. Check to see if there is any evidence of play left and right and up and down in the wheel. Also, inspect the control arm bushing to see if there is evidence of wear.
Let me know what you find or if you have questions.
