steering
98,000 MILES
KELPIE
car was running,no problems.parked it next morning,the steering wheel not turning.
p/steering full.at times in the past when you turn it tight,it will make a noise,this might be the traction control?other that this car runs great and is serviced regularly.any hints on what to do,as no way to drive it to garage.thanks
May 19, 2013 at 12:30 AM
HMAC300
  • 48,601 POSTS
if the wheel isn't turning it may be your ignition lock has locked the wheel and won't turn. try moving the wheel both ways then turn the key on and see if it turns. if it is just hard to turn then have the p/x pump checked for pressure.
May 19, 2013 at 12:39 AM
