Steering not working properly
120,000 MILES • 4.8L • V8 • 4WD • AUTOMATIC
CPERRY54
  • 35 POSTS
I am having trouble with my steering. I’ve change the gearbox, the power steering pump, new belt idler arm and Pitman arm and the steering is still stiff, what could be the problem?
Sep 17, 2020 at 1:45 AM
Good afternoon,
If you jack the front of truck up and start it, do you have power steering?
https://www.2carpros.com/articles/power-steering-problems
Make sure the ball joints are not locking up causing hard steering.
What kind of pump did you use? GM had tons of issues with there pumps breaking the input shafts resulting in no assist.
https://www.2carpros.com/articles/how-to-replace-a-power-steering-pump
Sep 17, 2020 at 3:45 AM
