steering
258,000 MILES • 4.2L • 2WD • AUTOMATIC
CASHJACK
  • 18 POSTS
changed: rack and pinion, upper and lower ball joints, front stabilizer bar bushings, upper arm control bushings, lower control arm bushings. used tape measure method to front tires for a close alignment. problem : test drive: drove thirty to forty mph no noise, tires smooth ride. slowed down to turn around to the right, loud pop noise from right side. then, both tires shook as i drove home.
Apr 8, 2017 at 3:49 AM
HMAC300
  • 48,601 POSTS
on some of these the bolt on upper control arm hits body check that there may be a witness mark there if it does bend body where it hits.
Apr 8, 2017 at 5:00 AM
