Starting troubles
210,000 MILES • 2WD • AUTOMATIC
MARTINNM
Car was working perfectly like seriously you could not ask for anything to run smoother. nothing sounded bad ran smooth. one day i parked it and stopped working. the engine rotates, acts like it is about to start but does not reach that point. I have tried disabling security system that did not work. i have tried resetting security system that did not work. I check to make sure engine was getting fuel that was working great. i checked compression that was also great. i checked spark plugs and everything those worked great. i do not understand what could possible be wrong.
Jan 31, 2018 at 11:41 AM
CARADIODOC
  • 34,413 POSTS
Since you have spark, the next best suspect is a jumped timing belt, especially at the mileage you listed if the belt has not been replaced twice already. All engines run backward just a little when a stopped engine coasts to a stop, and that jerking can cause a loose or worn belt to jump a tooth or two.
Jan 31, 2018 at 5:25 PM
