Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Oldsmobile
Cutlass
Engine
Symptoms
Stall While Driving
Engine will not stay started?
1991 OLDSMOBILE CUTLASS
170,000 MILES • 3.1L • 6 CYL
ROBERTFRESQUEZ
MEMBER
1 POST
Star car then shuts off right away. changed EGR idle control sensor, checked fuel filter, fuel pump, fuel injectors, and still same.
Oct 22, 2022 at 6:29 PM
Experienced Mechanic
The first thing we need to do is check for diagnostic trouble codes. What you described can be caused by a few different things.
This vehicle has an OBD1 system that doesn't require a scan tool to retrieve code. All you will need is a short jumper wire or even a paper clip.
Follow the directions in this link and let me know the results:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Oct 23, 2022 at 1:05 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
