Will not stay running?
100,000 MILES • 1.8L
ECLECTIC ECLECTIC
  • 21 POSTS
Greetings. I have the vehicle listed above z18xe. It starts and shuts off. Checked fuel relay/pump turns on. I have spark. Replaced cam and crankshaft/coil. It starts and idles if I cover the intake air filter or throttle body. Code from opcom says crankshaft low input signal. It does start and runs if I cover those. Thank you.
Jul 15, 2023 at 12:15 PM
  • 110,248 POSTS
Please understand, this vehicle isn't offered in the US, so I don't have manuals for it. However, I will try my best to help.
By placing your hand over the air intake, you limit the amount of air entering the combustion chamber. The first thing I think of is there is an engine vacuum leak at a different point on the engine allowing unmetered air to enter the combustion chamber.
Do me a favor. Take a look at this link. It explains how to locate a leak. See if you are able to find anything.
Also, let me know if you have a live data scan tool. Also, take a look at this link, it describes the most common symptoms of a failing crankshaft position. See if it mirrors anything you experience.
Let me know what you find or if you have questions.
Jul 16, 2023 at 1:30 PM
ECLECTIC ECLECTIC
  • 21 POSTS
Greetings. Thank you, Joe. I have Op-com and it would give MAF or camshaft sensor. I replaced the cam and crank sensors. The fuel relay earth to the ECU is a common fault. I bridge the fuel relay. I have fuel in rail, and it starts and shuts off. It starts and idles if I cover throttle body or air intake. Thank you.
Jul 19, 2023 at 3:33 AM
  • 110,248 POSTS
If you restrict the air going into the engine and it runs, something is telling me there is a large vacuum leak. By restricting the air intake, the engine is getting an air/fuel mixture it can run on. Have you been able to check for leaks?
Jul 19, 2023 at 1:30 PM
ECLECTIC ECLECTIC
  • 21 POSTS
Greetings. Thank you. Wouldn't it still run without the air intake connection/MAF? I have seen a video of one running. I'll connect the air intake hoses to throttle body.
Jul 20, 2023 at 4:46 AM
  • 110,248 POSTS
Yes, in most cases when the MAF is disconnected, the PCM will resort to a predetermined setting to the engine can continue to run.
Jul 20, 2023 at 11:27 AM
ECLECTIC ECLECTIC
  • 21 POSTS
Greetings. I have connected the air intake hoses. It still shuts off unless I cover it. It has fuel in rail, but the fuel pressure gauge shows nothing. I bridged the relay still shuts off.
Jul 22, 2023 at 7:01 AM
  • 110,248 POSTS
It sounds like the fuel pump has failed. If the pressure is that low, it won't run. Actually, by covering the air intake is the same as having a choke on an older vehicle carburetor. That forces less air and more fuel to enter the combustion chamber.
So, if I understand, the fuel pressure doesn't show any pressure. If that is the case, the pump is likely the problem.
Here is a link that explains in general how one is replaced:
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Let me know if that takes care of the issue.
Jul 22, 2023 at 2:36 PM
