Starts right up, then shuts off
226,000 MILES • 4.3L • V6 • 2WD • MANUAL
PAUL FARRAR
Truck will fire right up, let off the gas it shuts off. Give it too much gas it shuts off. Just replace fuel filter distributor cap and rotor. was running fine one day then all the sudden boom. Computer shows no code. Code 12 only route number 1 to TDC and distributor pointing right at it. I don't believe it jumped time.
Jul 20, 2019 at 11:08 AM
SCGRANTURISMO
  • 4,897 POSTS
In the diagrams down below I have included the factory diagnostic troubleshooting guide for Direct Trouble Code 12 for your vehicle. Please go through the guide and do exactly as it says and get back to us with what you are able to find out. We can go from there.
Thanks,
Alex
2CarPros
Sep 3, 2020 at 5:47 AM
PAUL FARRAR
Exact same thing. Flashes 12 that's it.
DOCFIXIT
  • 18,828 POSTS
Could be a fuel pressure issue or TPS maybe faulty. With no codes check the basics.
